OK- I replaced both ignition switch and starter solenoid. This cured the problem of starter motor turning over when key was in off position. As I was putting a tune up on and had engine running, points set, timing set, etc. it died, as if I turned the key off. It is getting fuel ok. What the #&*% is going on with this car now? HELP
