hey guys,
i have an ls5 in my car and a bent valve in the engine is most likely bent. how much am i looking at to fix it? If i were to totally replace the valve and have a mechanic do ti for me (remove the heads, have it sent out, put it back together? thanks (i got around $500-800) =(
well, if it's just a bent valve, you MIGHT be able to pay someone to do it for that much.
but valves only get bent when they hit pistons- and pistons are made out of soft aluminum
do you have other valve that are bent or worn?
is the valve bent from hitting on the piston?
you may have to replace all the valves + 1-piston and ????
