1 - 11 of 11 Posts
Doing a Body Off on a 72 Chevelle. While dis-assembling the rear axle from the frame I discovered the LH side lower shock mounting hole on the Axle is elongated (see Photo). The RH side was perfectly round.
Is this a problem? If so, any ideas on how it can be repaired?
Thanks,
Bob
Maybe a loose shock over time caused the hole to open up. :confused:
I would fill the bottom of the hole in with weld, grind it smooth/flat on both sides and re-drill hole, once painted you will never know it was there. :thumbsup:
If I was doing a frame off, I'd be doing this ^ ^ ^ ^ ^ (and even if I wasn't doing a frame off, I'd still do this ^ ^ ^ ) :D
x3..:yes:
you left out the duct tape..
jb weld/jb weld/jb weld/ sold in auto parts stores and even wal mart !!!!! We used this on one of our track cars (a 68 ' 10 second car) with flat washers that ripped the left rear shock absorber out at the track solved problem . Most professionals and classic car owners know of jb weld !!!!!!!!! Bob Rizzi/Rzzi's Auto Parts
No, do not use JB weld... :sad:
Weld the lower part and grind it smooth. Its the right way to do it. Welding washers would work fine, just doesnt look quite as nice.
1 - 11 of 11 Posts
