Recently redid my whole rear suspension and had the gas tank out and repainted. I put everything back in last weekend and everything works fine until you turn the lights on!
Now when I go to put the car in reverse, as the steering column starts to spin my temperature and gas gauge needles start to
dance, my clock and tach lights go out and the high beam indicator comes on! Then after it's all the way in reverse, things go back to normal. What did I do by taking that gas tank off and painting it!!? I hooked up the ground from the sending unit to the body but other than that I didn't mess with any wiring.
Any recomendations for troubleshooting will be well taken. Wiring is not one of my strong points if I even have any.
Scott Wolfe
Leck Kill, Pa.
70 Chevelle SS L34
Scott Wolfe
Leck Kill, Pa.
70 Chevelle SS L34
