Either way the result is the same: my '65 is suddenly taking the battery down.
I had installed a new master cylinder and was in the cab pumping the brakes when I noticed that my dome lamp went out everytime I pressed the brake pedal. Checking the battery I found it seriously discharged. After charging the battery up about 50% I got out my digital volt-ohm meter. On the continuity setting my VOM is giving audible buzzing from the main power lead (non-starter) off the battery.
I have a fair idea how to proceed and isolate circuits for draw/short testing. My questions are:
1) On a non electronic efi system with just the rudimentary electical are there common trouble spots?
2) Do one wire alternators have a little draw even when engine and all accesories are turned off?
3) What about the alternator diode trios and the horn relay?
Thomas
Shoudn't be any draw off the battery with the car off. Exceptions are things like a clock or a memory circuit. An aftermarket radio can contain a memory for a clock and presets.
Disconnect the negative cable off the battery. Put a test light bulb between battery (-) and its cable. The light should not come on if you do not have one of the above items.
One wire alternator will have small draw all the time. With out the "kicker" wire hooked up the alt. doesn't know when the car is turned on/off. That is why you have to "rev it up" a little on start up to get the alt going.
Dennis, that is exactly what I came up with - the draw was indeed coming from the one wire alternator. Apparently it had been longer than I thought since I had seriously driven the car - maybe three weeks. I had started it up in the meantime one day while working on the ignition advance, but it hadn't seen any road time for at least three weeks.
Thomas
