Gold Founding Member
Actually the capacitor splits the phase
Just had a thought, these CSR motors have almost zero starting torque and many times they just need oil and the dry bearings cause too much drag to let them start
a lot of them have no oil holes so I have punched holes through the end caps with an awl to oil them
The most common problem with these typ motors is the front bearing and shaft get worn a little and they're toast then cause even if you replace the bearing, the shaft is usually worn down too much
