Going to mount a electric fuel pump(mallory 140 gph) will a regular 30 amp relay work?
Marcus
Marcus
Yes it will. I'm guessing you have a nearby power source for the relay.Going to mount a electric fuel pump(mallory 140 gph) will a regular 30 amp relay work?
Marcus
Ok, but have no nearby power source have the battery mounted in front. So I´m going to mount the relay on front inner fender if you think it still will work with so long cable between relay and pump.Yes it will. I'm guessing you have a nearby power source for the relay.
That is where I mounted my relay, up in front of the battery where it's hidden. Works great! Make sure to use a fuse in the power lead to the relay, and use a big enough wire for the lenght and load. I'd bet you want at least a 12-14ga wire.Ok, but have no nearby power source have the battery mounted in front. So I´m going to mount the relay on front inner fender if you think it still will work with so long cable between relay and pump.
Thanks!
Marcus
