1 - 20 of 21 Posts
Hello all,
I am buying a new carb and was wondering if I need to get one with an electric choke or not? The car is only a weekend warrior, and it never really gets that cold where I live. Would there be any disadvantages to not having a choke?
thanks
Joe
Well you could get by without one but, why? Unless you are interested in every bit of power I suggest you opt for ease and good driveability. Even in California it does get cold at night and in the winter.
Redrum (or Mike)
68 Corvette - 383 CI 427 HP
69 SS Chevelle being updated to Pro-Touring
97 Z-28
YES
Greaseball
Brandon FL.
Team # 660
67SS 69SS
You dont need a choke. Pump the gas before you start it, feather it for a few seconds as it starts. let is sit and run fo a few mnutes befre you drive. No Choke
Pumping the gas puts raw gas in to the cyl and washes the oil off the walls.With a choke you get a rich mixture instead of raw fuel.Run a choke and set it on the light side,it also give you a fast idle for warm up...FRED
Pumping the gas puts raw fuel into the cly and washes the oil off the walls.A choke gives you a rich mixture not raw fuel.Also gives a fast idle for warmup...FRED
I would recomend just taking the choke off, I just did it to my 71'. I made my edelbrock 600 cfm. Into a 645. All I have to do is just hold the gas a little bit at start up and then give it a little gas to keep it going. And I have no problems at all after that. You may have to play with your idle screw a little bit. And that's all I have to do.
71 malibu350
I have never bothered with a choke on a weekend warrior. As I see it you will only need it when you initially start the car for an outing, and it only takes a few moments for it to run well so I don't really think it is necessary. It just boils down to what you want, something that runs well as soon as you turn the key or something that will take a few moments to do so.
Steve R.
Thanks for all the help.
I did notice that if you buy a non choke carb (edelbrock) that the jets are bigger than if you buy one with a choke. For instance on a edel-600 cfm no choke, the carb has Metering Jets: primary .100, secondary .095; Metering rods: .070x.047 ; spring orange 5hg.
On the 600 cfm with electric choke, it has Metering Jets: primary .098, secondary .095; Metering Rods: .075x.047; spring yellow 4hg.
Why would they do that? Does this make a difference in which carb to buy?
Thanks again for your help
Joe
buythe one with no choke. I'm telling you dude, out here in CA, a choke is completely unnecessary.
I live in CT and have gotton through the whole winter without a choke. Just pump the gas twice before you crank it and give a couple of minutes to warm up you will be all set
Ya know, it's amazing how much money The General could have saved if chokes weren't necessary. Dang, someone in Engineering should have though of that!
MalibuJerry350
Original owner '70 Chevelle.
540,000+ miles on car.
My Chevelle: http://hometown.aol.com/erie614/myhomepage/index.html
Alright Jerry, I'll rephrase....they arent TOTALLY unnecessary, but I would call them one of those convinient features that isnt a necessity. Like A/C. By the way, thanks for your help with my PCV question.
Eric
You guys make me laugh. Sure for a daily OK, but for a perf vehicle
" YOU DONT NEED NO STINKIN' CHOKE" . I dont bother. The only key is NOT to pump the thing and goose it while its running. Fire it, run it up to 1500/2000 rpm and let it stay there W/O pumping it. But I run Holley 850s and tripowers. Guess if I was putting an EDEL 600 on something for my wife, I run one.
Gene Chaas
Gold Member 62/ACES 3110
67 SS 427
"Be big. Be a builder."
on my 454 daily driver (not stock) i use a holley 950hp carb they dont' come with a choke/vac. lines, NADA, they are clean, and in texas it does get cold in winter, 2 pumps, fires on first revolution, then just feather for a couple seconds. no wires/no cables nada, clean as a wissle under my hood,
a
and from what i've heard most holley's run rich anway and there's really no need for a choke. my car came with a 750holley originaly with the choke cut off, from Minnesota, no problem
1970 SS396 AKA 454/4spd
My Chev-Hell Page
Member #783
Ft.Worth, Tx
Big Block Chevy.net
proud owner of this site
Oh yeah, I should add two more "points of info",; 1.) I live in Buffalo where its really tropical, but have fired the old girl at less than 30 degrees. No prob and 2.)more importantly, I am also a freak that doesn't take my gearbox out of neutral until I see the temp guage begin to move.
Its a litle bit of a hassle, but no big shakes.....
I'm with 427L88. I have a 750 double pumper in my 85 El Camino and live in Ohio. It's my daily driver and I have no problems starting it when its below 30 out. Just gotta keep it around 1500-2000rpm for awhile till it'll idle. Then I just wait till the temp. moves and I'm gone.
1 - 20 of 21 Posts
