I just put on an aux. fan and decided to spend the $50 and get the fancy thermostatic control switch. The fan is a Derale Tornado and the switch kit is from Permacool, 160-210* adjustable turn on. Has a "probe" that inserts into the radiator fins. I have the switch set at 160 just to test it.
I mounted the fan and gave it a direct 12volts and it works fine. But with the fancy therm switch it doesn't work. Its just not clicking over. My engine has a 195* stat and a water temp gauge so I know that thing should turn on.
Seems that 12v are getting to the (Module) thing but from there to the fan there is nothing.
Any suggestions?
Any suggestions?
