1 - 2 of 2 Posts
Hello All, My Daughter's '69 E/c was the victim of a hit and run (actually a scrape and run)anyway, I need to know if the piece behind the taillight housing that you actually put the bulb in can be replaced, if any one has one, or if that part is reproduced? That piece took the brunt of the wreck as it appeared to bend until it popped out of the back of the housing. It is the brass piece surrounded with an aluminum housing w/a flange at the end to put into the taillight housing. Thanks, Brad
1 - 2 of 2 Posts
