Seems like about 100 photo's. What do you think about the claims, engine block stamp, misc restoration details? Looks nice.http://cgi.ebay.com/ebaymotors/Chev...0100428941QQcategoryZ6164QQrdZ1QQcmdZViewItem
The clock is automatically moved to the console when console ordered. Panel and stem plug is normal when gauges are not ordered and console is.Clock delete looks different
I took issue with the VIN rivets also Jim, for some reason I don't think they should have a stem in the middle of the hole like a pop rivet, and engine stamping looks off, size looks way wrong, and I know every plant did things alittle different but I don't remember seeing a 1 like that, not saying they did stamp them but wern't most stamped using a I for a 1.Engine stamp looks skeptical. Matching #'s, 69 rear for a 40,000 mile car, no assemble date or vin on the m21, Delco must have got that alternator there fast (dated March 4 & build date 2nd week of March), and correct starter(wheres the date). Lots of photo's but none of the undercarriage, what about that date code & vin # from the frame. How could someone get all the engine detail wrong from a 40,000 mile car? Don't you think the closed ventalation PVC setup should be correct along with the air cleaner top. Must have forgotten which way that original alternator was installed. Correct 66 PS cap & correct alternator fan. Where is the build sheet? Claims Original interior , got it unrestored; don't you think he would have found it by now, if he restored the car. Nice looking car; But how can he call it matching #'s? Did you guys spot the bolt instead of the rivet on the grill picture? Vin rivets look OK to me.
DUH. I guess I should read a little closer. All I saw was retains original sheetmetal.Doesn't the add say it was repainted??
