A while ago I was talking about the importance of finding a good tuner who knows his stuff and a few members found it tough to believe my car picked up 118 hp and 84 ft/lbs from dialing in the timing and getting the proper jetting. So here's the sheets that were asked for. The car is a 79 Malibu with a 468 fully studded BBC, 680 lift solid flat cam, around 11:1, L88 074 aluminum heads, old Holley strip dominator with an old 850 dp. Best run was 10.90 @ 123 mph.
Not the best pics and a little faded but first pull 35* and factory jets peaked 488 hp 486 ft/lbs, best pull 38.5* and 92/92 jetting achieved a best of 606 hp and 570 lb/ft
I will note that no parts were changed these are the same session with a change of timing and jets
I believe with a modern carb, intake and ignition system this motor has more potential
I'm a believer too. I had TPIS dyno tune my car on their chassis-dyno a couple years after doing my EFI conversion. I wasn't looking for a power upgrade as much as just fixing some glitches from the homemade chip we were using. They not only fixed it over the whole curve, but I picked up a little over 50 hp at the wheels too.
It seems that the only people who don't understand how much there is to be gained by a dyno tune session are those that have never experienced it themselves.
Some of the best money to be spent....without a doubt.
Not always the case! I have seen some well tuned track cars pick up NOTHING from the dyno-tuning on a chassis dyno. The one is a good friend of mine, and after 3 hours they gained NOTHING.
John: The question becomes - How did they get so well tuned? How much TIME was spent doing so?
Even if you get lucky and find the right "mix" on your own, it usually takes a LOT more time (and money) doing it on your own than going to a tuning dyno.
Disclaimer: Guys running EFI have a major advantage here and can get in the neighborhood quite often with whatever "computer" they are using. Guys running carbs have the most to gain here.....IMHO.
MBT is allot easier to find on a dyno. Working out timing for your af mixures you can use a wideband and read plugs to af in line but to get the timing right it takes allot of controlled measured runs either down the 1/4, 1/8, or dyno. Tuning is done through stradagy. I look at a dyno as a time saver when I get my efi tuned on a dyno I will go with a plan to maximize my time there.
