Trying to figure the best cam for my combo so would like some help figuring my dynamic compression. Heres how it looks.
60 over 454 flattops, .023 deck hieght with .020 steel shim head gasket
94cc 702 big valve heads static compression of 9.7:1
Will be running 94 octane, timing advance ?
Thinking of running the Lunati Voodoo 60204
Hydraulic flat tappet
RPM Range 2,200-6,400
Intake Duration at 050 inch Lift 233
Exhaust Duration at 050 inch Lift 241
Duration at 050 inch Lift 233 int./241 exh.
Advertised Intake Duration 276
Advertised Exhaust Duration 284
Advertised Duration276 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.554 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.572 in.
Valve Lift with Factory Rocker Arm Ratio0.554 int./0.554 exh.
Lobe Separation (degrees)110
