Doing the hydroboost conversion. Two questions:
1- Is there a two return line power steering pump that I can use the stock pulley on(screw vs. press on)? Or if not what pump and pulley(V type and size) will work?
2- I purchased this setup from a member years ago. Was on his 70 he said. It appears thew push rod needs to be placed in the top hole for the push rod to be straight. The brake light actuator plate is mounted there. Anyone dealt with this and what was the resolution.
I'm sur ehtese are "dumb" questions but for me the are relevant. TIA Pete
Most GM trucks with hydroboost used dual return line pumps. You can probably get the reservoir from the truck pump and use it with your pump, since most 70's and later trucks used press on pulleys.
My pump is from a 1 ton GM Work Van with Hydra-boost. It has the 2 drain return lines and allows the hydra-boost to work great.
