1 - 2 of 2 Posts
in reading thru these posts i thought to have seen where yoy can run the stock front disk /rear drum setup(master/prop valve/dist block) with rear disc brake conversion if you added a adjustable prop valve to the rear brake line. now i can't find the post .is this possible??? it would save me running a new prop valve, removing the dist block and redoing all the brake lines. thoughts???
1 - 2 of 2 Posts
