1 - 17 of 17 Posts
I'm nearing the end of my Manual to auto swap and now I need to order a Driveshaft. Is there someone that comes highly recommended by anyone. I live in CT and would like to get a shaft locally rather than order from across the country. I want a 31/2 in. cromoly one and as we all know in this hobby, we want it as soon as possible.
Cammorotas truck parts on universal drive in North Haven will build you one.Reasonable price and does really nice work.
I just bought one from Dennys driveshafts
Only took about two weeks and it was in my hands.
Now if I can get everything else done I could test it out.
Thats who I recommend and hes in upstate new york i think.
X2 on Denny's driveshafts. Mine took a little longer, but was worth it.
Thanks guys, I will check them out.
I used Denny's Driveshaft on my last purchase also. :thumbsup:
Does Denny's make a Cromoly shaft? Do you think an aluminum shaft would be ok on a 3800 car?
I have been waiting for over a month for my drive shaft from Dennys, but i their defense they are waiting for the 1350 pinion yoke I ordered with it
Thats what I'm afraid of. I don't want to be waiting around that long. Everything else is done for the swap and I would go crazy waiting. I understand quality but other places should be able to produce quality pieces.
I'm not sure how you intend to use your car, but I race my Chevelle at the strip regularly, 3950 pounds race weight, 496, TH400, high 11's in the 1/4 mile with 1.6X 60' times, and I have had no problems whatsoever with a stock driveshaft. I have a new slip yoke from Denny's that takes a 1330 u-joint. A local driveshaft shop shortened the driveshaft (my car came with TH350) rebalanced it, and put new u-joints in it for around $100. Turn-around time was less than a day.
The driveshaft I got from Dennys is aluminum
71 chevelle,475 (vortecpro)bb w/588lb.ft.4l80 manual shift 2800stall
Talked to Denny himself did all the calculations
All good
But I still havent drove the car
Discussion Starter · #17 ·
Thanks guys,I will check them all out before I make a decision.
1 - 17 of 17 Posts
