Uphill out of the trans you have to add the uphill angle to the driveline angle, downhill out of the trans you subtract the angle. Big difference.Uphill out of tranny means diff pointing down makes it exactly same.
This indeed is an issue with many of the "explanations" of setting / adjusting driveline angles. I recently went thru this adjustment exercise. After looking at various "how to" directions I had a discussion with a fellow who could clearly describe the process. One key aspect of his explanation was defining what is "up" and what is "down" in terms of the components in the driveline.The thing about the driveline angle threads is the confusion between “up” and “down”.
I hear ya' 🙄Pugsy linked a PDF in post 14 that tells you all you need to know in no uncertain terms. IT IS SO EASY !!!!
You can lead a horse to water.....................
I'm a little late to this discussion, but just wanted to reply to the OP's original question.My drive shaft will need to be 56.75” long. I was planning on a 3.5” diameter driveshaft but I’m not sure if that’s going to be enough with 3.73 gears, a .80 5th gear, and 26.65 diameter rear tires.
Thoughts?
Where is this site?
As previously mentioned... the overdrive trans slows down the rpm's of your engine in 5th gear, but does not slow down the driveshaft's rpm's (since the driveshaft's rpm's are only based on differential ratio, rear tire diameter, and vehicle speed). If your engine was spinning at 5000 rpm in 5th gear (.80 overdrive), your vehicle speed would be about 133 mph, AND the driveshaft will be spinning at 6250 rpm. At 6250 rpm's, your driveshaft would be spinning at about 90% it's critical speed.So, my 3.5 may not be enough at 5000+ rpm in 5th gear.
Short answer... liability.So, they list 80% of critical speed, why?
