1 - 8 of 8 Posts
all of the sudden the drive shaft is hitting the floor pan where the trans tail and drive shaft meet (u-joint). i thought it was the trans mount so i swaped that out and it just made it worse. could it be a bad u-joint or motor mounts i dont know. what are some things that can cause this problem . i need all the help i can get
It could be your floor pan braces are rusted out allowing the floor to sag down. Are your body mounts original? They compress/ dry rot over time allowing the body to sit lower on the frame... or maybe a combination of both conditions.
You can also remove the tranny support member and shave some metal from the rear tranny mount area and get it a little lower.
1 - 8 of 8 Posts
