Should be 26 😂Picking up 24 MPH on the back half...
My 496 picked up 25, there’s more in the tank.
Not easy to change bleeds in the carb then without removing the restriction and tapping.And that’s a wrap for today. 11.72, 11.75. 11.79, 11.84, 12.08 (spun)
She’s running out of fuel up top, no doubt about it.
I’ll make a pass or two in the AM (cool air) and head out.
Carter Strip pump. I need toat least remove the sock, but probably upgrade to 1/2” to the mechanical pump. Then, I have a block 90° that’s late to leave this car. These items will be updated before Midwest Drags. Hopefully we see some 11.50s that week.Not easy to change bleeds in the carb then without removing the restriction and tapping.
You have 3/8" lines, what fuel pump again?
You didn't want to go to a non stock looking pump, like a Holley 12-454-20 170 gph? It says to use with a regulator, but it works fine without one.Carter Strip pump. I need toat least remove the sock, but probably upgrade to 1/2” to the mechanical pump. Then, I have a block 90° that’s late to leave this car. These items will be updated before Midwest Drags. Hopefully we see some 11.50s that week.
PS I wish I would’ve tried the locked out MSD on my 496 to see the difference. The car leaves on a mission.
I hope to see 11.60s tomorrowCarter Strip pump. I need toat least remove the sock, but probably upgrade to 1/2” to the mechanical pump. Then, I have a block 90° that’s late to leave this car. These items will be updated before Midwest Drags. Hopefully we see some 11.50s that week.
So if a car runs 11.43 @ 112.90 is it running out of gas on the top OR is it very efficient use of the HP available?Picking up 24 MPH on the back half...
Congrats on the 120 MPH pass and a new best (for now!)
543 hpMike what did we have for observed HP with your carb in Killeen, remember 3000 foot DA there that day.
At what rpm is it making 600 hp? This engine is at 600 hp by 5000, pump is actuated far less times, relatively speaking.Not trying to debate the larger fuel pump and lines definitely a good idea but my sons 406 made 600hp on the dyno and went almost 125mph with a stock auto zone pump and stock 3/8" lines/pu.
Timing locked at 36* and 3.42's
That said he was probably 1k under what he made peak hp going through the stripe with the lower numerically gears.
Does the extra 104 ci make a difference or is 600hp 600hp?
I'm in no way doubting what your feeling.At what rpm is it making 600 hp? This engine is at 600 hp by 5000, pump is actuated far less times, relatively speaking.
But, this certainly feeling like a fuel issue to me. I might just try to shift to drive tomorrow…bang some more torque at the end to see what happens. My guess is the loss of gearing makes it a wash. A 28” tires makes this go away 😂
Seems you can race dyno's, it nice to see our performance simulations seem pretty accurate.
So which is it, 10 gph or 20 gph per 100hp?I would recommend a fuel pressure Monitor inside the car or at least an afr gauge.
Fuel pump rating are free flow and rule of thumb are half of that at working pressure of 6-7 psi.
Another rule of thumb is you need actual 10 gph per 100 hp.
So - for example - when you need to fuel 650 horses i would aim for a pump that can provide 130 gph at peak hp.
So a 130gph pump is the bare Minimum i would say.
Best is one with proper pressure like 15-16 psi, or edelbrocks 10 psi 1712 pump. i use that one with my man 496 with a billet Regulator.
Only use straight fittings.
Works for me with 3/8 lines and pick up.
Can run 0-130 mph and pressure is Rock steady
