There’s a learning process involved in everything…distributor gears.
Bullet Cams tech support verified cam in the 510 is ground on a 1050 steel core, so it needs a special steel distributor drive gear ( the same as GM factory roller cams). He could not say if MSD’s melonized cast-iron gear was suitable or not, but according to MSD, it is.
However, at this point I’ve read enough horror stories about using a factory HEI cast iron gear, as well as MSD melonized cast-iron gears (85551 is supplied with gear 8531, according to Holley tech support, and 8561 is a more expensive “marine” labeled version of the exact same gear), that I have to hit the pause button to be sure.
The sure bet is the steel GM gear 10456413 (0.491” shaft), but my local GM dealer stated that GM has discontinued the gear.
This article below states that late model HEI distributors used on roller cam engines also had the steel drive gear. The large cap HEI distributors fitted with the steel drive gears lack the vacuum advance canister, as does mine, but there are far more years of large cap HEI distributors without vacuum advance prior to roller cams so that’snot a sure bet either.
The lowdown on small-block Chevy hydraulic-roller cam distributor gears, lifter adjustment and break-in.
www.motortrend.com
Anyhow, Howards has steel gears on hand:
94404 - 0.491 shaft (GM points and large cap HEI
94409 - 0.500” shaft (MSD)
Order placed NDA, hopefully the gear arrives before the race so I can sleep at night.
