1 - 1 of 1 Posts
Does anyone know the part number, or even the name of the door switch used in the power seat back release circuit? It's not the same as a dome light. This one has two or three very small round pins instead of flat tabs. I need to get some new or used ones.
Also on the door switch topic, the Fisher manual says to set up the dome switch to slowly close the door, it sounds like this slides the entire switch in the assembly to the correct depth (actually crushes the sleeve inside the nut). I've noticed on one used dome switch I installed that it's not close to being long enough to turn off the dome light. If I get a "used" switch for the seat back release, can it be readjusted?
1 - 1 of 1 Posts
