Stating the obvious: check the fuse. Remove it and test it with a meter to be sure. Also make sure the fuse socket isn't corroded. Dash lights usually share a common connection. Does that car have a dimmer? A ratty dimmer control will also cause the same problem.
Bruce L.
Bruce L.
