I was fortunate that the previous owner had the SS dash and console, but just didn't have the moxy to install them.
He's where I am as of today - The malibu std. dash came out with a lot of work. About 7 dash frame bolts after I dropped the steering column to get to a bolt just above it. This included taking the column coverplate off of the firewall on the inside by the brake pedal. Not as hard as it sounds.
Many connectors later and the dash comes loose. It's tricky getting it out the door but be patient!. Oh, to get the harness connector off the firewall, there is on bolt on the engine side that holds the engine/headlight/alternator harness connector in place. It's a tough bend to get to. More patience. Two long screws hold the interior side in place. To separate, place a long screwdrive in the righ spot and SLOWLY pry. Poppped right off.
I'm keeping everything for reference and for needed parts. While I'm in there I'm cleaning everything like the air ducts and re-glueing the insulation that has come loose. Also painting some areas that look like rust may be starting.
This weekend the new dash goes in. I really don't think, now that I'm into it that it is going to be all that hard. Just slow.
I've got my cooler of ice tea, CD player and my wife is going shopping with here sisters for the day. What better situation!
I'll post here as the process continues.
members.tripod.com/dfdolerjr
