I have been having starting problems battery drain etc...and I found this ...
does it go into the box behind it or is it a test lead ? it is on the rad support right behind left side headlights ...
thanks for any input
69? That connects to the horn relay, it's part of the key warning circuit. With it connected and all other key warning circuit connections, wiring and switches in place the horn relay will buzz if the key in the ignition and the drivers door is opened. It will not cause any problem if left as is.
