Does anyone make a front caliper bracket for 69-72 Chevelles for upgrading from 11" to 12" rotors?
These brackets will mount 2000 Camaro LS1 brakes (12" rotors) on your Chevelle
The calipers are double-piston and twice as big as single piston 11" calipers and are a huge improvement
Administrator
Church Boys Racing sells them too for about half the price. They are not on the web site, call Chuck to order.
Church Boys Racing
Is this update really that much better then the stock 11" disc/drum set up on my 69 el Camino for example?
Discussion Starter #5
I am looking to try using the drum brake hubs, C3 Vette rotors and the 85 Suburban 3-5/32" piston calipers with the stock 69-72 spindles (68 likely the same but those used the 2-piston calipers therefore the brackets are likely different unless you use the single piston caliper). Basically the same as what I did on my Chevelle convertible, except without the B-body knuckles.
