not much advantage with your current rear gear ratio = with an overdrive transmission you might want your effective gear ratio in overdrive to be in the 2.41-3.23ratio range. you are already in that range. for a street car i would leave it alone unless you want to change rear gears and install an OD-trans to get your overall/effective gear ratio back to the range it is now:thumbsup:1970 Chevelle with 1993 TBI engine, currently with 2 bbl carb, 2.73 rear gear.
What advantage is there to switch the TH350 to overdrive?
Exactly what I paln on doing this fall as well.Would I do it? Yep. But eventually I'd go for a 3.42 or 3.73 rear gear.
X2. I have the same setup in mine. If you do the math the final drive ratio with the 4.10 in OD is 2.75, almost exactly what you have now but the real advantage, as chevyefi already mentioned, is in 1st thru 3rd. I run 2,400rpm at 70mph on the highway. If you keep your current 2.73, OD will drop your final down to a 1.83. Unless you have tons of low end torque it's going to lug so bad that you'll never use the OD. I had an `83 GMC pickup years ago with that combo and the only way it would even stay in OD is if I could keep it above 80mph, and even then it had to be on a straight flat road with a tail wind behind me.2.73 gears? what do you want OD for??
i have 4.11 with a build 200-4r and love it. best of both worlds.
700R4 or 4L60e?1970 Chevelle with 1993 TBI engine, currently with 2 bbl carb, 2.73 rear gear.
Please explain that sentence.I wont ever look back on THIS car for the drivability.
X2 on what Ron said. :yes:Charles,
Your 2.73s are a nice highway gear. However for quick acceleration/drag racing many think they aren't as good as, say, 4.10 gears. Guys who use 4.10s and similar miss having a highway gear for cruising. The OD trans gives them an extra gear above drive to lower RPMs/fuel consumption on the highway. The only good reason for you to get an OD trans is if you wanted to swap your axle gears to something stouter like 4.10s etc. Hope that helps.
The goal is gas mileage!
Stock 1993 350 with added 4 bbl, stock 1970 Chevelle body and suspension, stock 2.73 rear gears.
Now running stock 1970 350Th transmission and have a stock 1993 700R4 in the shed!
For highway mileage; say Charlotte, NC to Wisconsin Dells, and later this Summer; Chicago to Santa Monica, will the 700R4 do me justice or will it hurt the engine?
I have after market cruise control.
The long trips this year are Hot Rod Power Tour and Route 66 end to end.
