Hey guys I went to the track today trying to get a new best and failed again. I feel that I have a few more tenghts in it, but want to see what you think.
I made three passes before the rain started. Here are the break downs.
BTW my best ET is 11.53 with the stick and auto. Best ET with the stick was 118.75 and with the auto 116.80.
1st run: launching off idle at 1400 rpm shifting at 6200
60ft-1.6259
1/8et-7.3739
1/8mph-92.81
1000'-9.6609
1/4et-11.5988
1/4mph-116.39
2nd run: foot brake to 2000rpm and shifting at 6200. lower timing from 38* to 36*
60ft-1.5999
1/8et-7.3710
1/8mph-92.40
1000'-9.6650
1/4et-11.6088
1/4mph-116.01
3rd run: same launch and shift point as 2nd run. Lower jets from 85/93 to 83/91
60ft-1.5919
1/8et-7.3560
1/8mph-92.35
1000'-9.6501
1/4et-11.5901
1/4mph-116.23
I planned on putting the timing back to 38*, but it started to rain.
I think that the engine itself is tuned pretty well and just needs a little more fine tunning. There are a couple other things I am wondering if they will give me a few more tenghts. I am currently running a 26" et street drag radial and I am crossing the line at 6800-7000 RPM which I think is way too high and I feel I might be loosing sometime this way. what do you guys thinks? I will be switching to a 28" tire either way. Second is I am using a 25 year old converter that I got from my uncle that flashes to 3500rpm. It does not seem to hit very hard. It was recommend to me by another member here to go with a 4000 stall. Also my engine builder recommended a 3800 stall if I ever went with an auto which I did. (originally had a four speed behind this engine). Is there a significant gain to be had with a quality stall that is in the 3800-4000 range for my engine? BTW this engine is in a 3800 lbs 56 bel air. I am open to any suggestions about the above or anything else you guys can think of.
thanks
Tom
60ft-1.6259
1/8et-7.3739
1/8mph-92.81
1000'-9.6609
1/4et-11.5988
1/4mph-116.39
60ft-1.5999
1/8et-7.3710
1/8mph-92.40
1000'-9.6650
1/4et-11.6088
1/4mph-116.01
60ft-1.5919
1/8et-7.3560
1/8mph-92.35
1000'-9.6501
1/4et-11.5901
1/4mph-116.23
thanks
Tom
