1 - 2 of 2 Posts
for months now I haven't been able to bleed my brakes after my drum to manual disc brake conversion. Everything is new other than the rear drums which were done a couple of years ago. I've bench bled the master cylinder twice, checked and double checked all the fittings, installed speed bleaders and nothing has worked.
Anyways I took off the master cylinder and found that the boot that holds the push rod had brake fluid in it. I bench bled it again and fluid comes out slowly. does this mean the mc went bad?
1 - 2 of 2 Posts
