Hi guys,
I have a set of '68 (I believe because they have the release button on the back) buckets in my '66 & was wondering if the 2 parts of the tracks come apart. I want to blast & refinish them but can't tell by looking between them. Is there a tab or something you can press to seperate them? I'm talking about the part that does the sliding & the part that bolts to the floor.
Thanks a lot!
George
[email protected]
TC #1921
ACES #5880
The ones on my 67 came apart. I found out because when I had them recovered, the upholstery shop reversed them left to right and they would not install. I don't quite recall, but I think they will just slide out if you hold the catch out of the way. You might have to remove a spring and a bolt or two for clearance. If you spend a few minutes studying them, I think it will become apparent.
Thanks,
I had them in the vice and tried to seprate them but no go. They are very dirty & I can't really see inside where the 2 parts slide against one another. I'll investigate it some more.
Thanks!
George
[email protected]
TC #1921
ACES #5880
George,
No, the track assemblies do NOT come apart! I sandblasted some while they were together. Just clean all the grease out of the tracks first, using a solvent, and let them dry completely. Then sandblast, blow all the crud out when you're done, paint, and re-lubricate the ball bearings and the tracks. They looked and worked like new.
