1 - 20 of 22 Posts
Hi everyone. This is my first post so take her easy on me. I just bought a 1971 chevelle ss clone. It has a 350 SBC with a distributor that I've never seen. Now I don't have much experience with timing but this distributor dosent seem to turn like most to adjust timing. It does have a port hole on the cap with access to a screw. I turned the screw a few times (counter clockwise) and took her for a spin. The acceleration seemed to be a lot snappier and pull through second gear a lot better. I was having problems with a sluggish wot and messed with the carb with no change so I figured it was a timing issue. So does anyone know exactly what that screw does? Is it actually advancing or retarding my timing. Thanks for looking guys! I'll try to post some pics. I don't know what brand distributor it is....
Did you use an allen wrench to turn the screw in the hole. Like Pearl said your changing the dwell when you do that. You have to have a dwell meter to be be able to set the dwell. The dwell should be set at 30. To move the distributor itself to adjust the timing you have to loosen the clamp at the base of the distributor but the dwell has to be set right first.
I didn't adjust at the vaccume hook up. Theres a porthole on the dis. cap that you can open to adjust the dwell. It's a flat head screw. Im trying to upload pictures but it won't let me. Anyone have advice on how to upload? Thanks
The porthole your referring to is a small little sheetmetal like door that slides up right.
To upload a photo just click on the photo it should show it's been uploaded close the window and then send the message.
I've never seen anything other than an allen wrench used to adjust the points unless they've changed it. Are you sure your not loosening the screw that screws the condenser and distributor wire to the points.
You sdet the dwell pretty closely without a dwell meter. Install the wrench in the screw and rotate counterclockwise until the idle becomes rough. Note the position of the wrench. Now turn it clockwise until it runs rough. Note the position of the wrench. Turn the wrench to the midpoint between the two rough idle settings. That will get you in the 28-32 degree range.
Discussion Starter · #13 ·
thanks J Wagner. It seems like I have set pretty good now. I'm still having trouble with my throttle response under load. It seems like I get different results when adjusting the dwell. Would adjusting the actual timing by turning the distributor be the best way to get the throttle response I'm looking for or could the dwell be used to fine tune response. Thanks for reading
My recommendation is to learn how to do a tune up. Very easy. Buy a tach/dwell meter, a timing light, and a spark plug gap tool. They're cheep. Get a book and look up the specs for your engine and set it up the way it's supposed to be. For example, inspect and/or replace spark plugs. Spark plugs gapped to .035". Remove cap and inspect the points, if they're pitted, replace them. Set to 30* dwell. Set the timing. Probably around 8* timing advance at idle with the vacuum line off and plugged. Hook up the vacuum line to the distributor and set the idle. Probably around 600 rpm in drive if it's an automatic, 600 rpm in neutral if it's a stick. Do it in that order, otherwise you'll be chasing issues around and around because one thing affects the next. Dwell effects timing, timing effects idle speed, idle speed effects timing. That's why it's to be done in order. Once you have it properly tuned, then you'll know if you have an issue that needs addressed. If you just start messing around with things, odds are you'll be masking or compounding a problem if one exists. jmo
OK, I've never seen points with the screw driver slot in them but it's been about 20 years since I had a points distributor. Gary gave you very good advice follow what he told you and you should be headed in the right direction.
Thanks for the help guys. I think I'm going to purchase a new distributor... sounds like the one I have is outdated..
Outdated? Sure. They work just fine though. A real GM HEI distributer and wires will set you back a couple hundred bucks. I don't think I'd trust the $40 ebay specials. If that's what you have in mind, make sure there's enough room between your distributer and firewall.
1 - 20 of 22 Posts
