I searched and could find an answer, trying this...
I'm looking for distributor rebuild instructions for my original points dist on my 67 327. The shaft has about 3-32 play up and down and is a little sloppy at the rotor, which may be causing some gear noise/wear. Methinks it's time to rebuild it.
Anyone have a link to a good distributor rebuild page/instructions?
Eric,
Check your e-mail. Sent you an article that I have on my Corvette side of the house that talks about rebuilding. If you ignore the tach drive and such I would bet major part of the article would apply.
G
Discussion Starter #4
Thanks to you both. Per the article Geek's 65 sent, the end play should be .010". Guess I'm rebuilding a disty this weekend.
