I went to test fit a GM HEI distributor into my new 468 with an Air Gap intake manifold and I made sure the distributor shaft and oil pump were mated correctly. The distributor base would not sit flush to the intake. There is about a 3/16" gap. Is this typical? I would have thought that with as common as this combination is that a special adaptor ring or a slip collar distributor would not be needed. Am I wrong? It's just a standard 4 bolt 454 block.
Thanks,
Dale
Thanks,
Dale
