I was adjusting the points on my 71 Chevelle 307 and the lead to the condenser came off. I cannot seem to find online where it connects back. I do bot want to hook it up to the wrong connector.
It should have a U shaped connector on it and just pushes into the points where the curved springs are bunched together, good luck!
If it is the ordinary GM distributor you have one choice. That is to put the condenser wire at the same place the wire from the ignition coil attaches.
