It sure will,It all bolts right up.
You may have to relocate the proportioning
valve though, but I'm not 100% sure
good luck!
Jeff
You can use parts from any of the GM A-bodies
up to at least 1972. You must also change the
spindles to be able to mount the calipers, and you must change the master cylinder to a dual reservoir designed for disc brakes. Try to get everything from one car. And order any replacements parts for that car.
