i have a 70 chevelle, i converted if to front disc with a complete kit, included was a booster and rod, m/c, prop valve and complete spindles with brakes... i installed this kit and cannot get a pedal at all, my problem is i have no front brakes. the brakes bleed fine with lots of pressure when bleeding, you have a good pedal, you wait ten sec and the pedal goes to the floor, again you have no front brakes you can pump it up and its got a good pedal but no front brakes.. ive put new m/c on, new prob valve, and still nothing, im tired of fooling with it i need help so any sugestions would be helpful. thanks
