I have tall spindles on my 67 but I don't know where to measure. If someone can tell me what/where to measure them, I will give it a go. If someone has the short spindles, we can compare the numbers.
I also have Hotchkis upper "A" arms. The distance from the mounting shaft (I forget what its called) to the grease fitting of the ball joint (approx center), measured with a tape measure, is 9.25". The arms appear straight without any offset.
I think the change to tall spindles was in '76.
Hope this helps,
Pat Kelley
66 & 67 El Caminos
[This message has been edited by Pat Kelley (edited 07-04-99).]
