1 - 9 of 9 Posts
Well I had no choice in having to drill (etc) my fill plug out of my rear differential and was wonder 2 questions from you guys. First question is does anyone know the tap size? Second question does anyone make a bigger fill plug in case I have to go that way (fingers crossed). Any help would be great been fighting a battle and want to finish this rear axel up finally. Brandon
It's apart no fluid has been installed since new gears just got to tap,install new plug and clean metal out (brake clean i wanna say to use).
This tap going to be something I can find local like lowes/home depot or something I need to order?
If you have a napa store near you, it wouldn't hurt to talk to them, they might even have you helicoil it, and it might be cheaper then getting a bigger drill bit and tap.
The helicoil will require a drill bit also but it might come in a kit and save you some money.
Rob
You're not likely to find NPT taps at Lowe's/Home Depot. Mcmaster-Carr sells them. Check their website at Mcmaster.com. Pipe taps are not cheap, neither are the large drill bits. Prepare to spend 40-50 dollars for the tap and about half that much for the drill bit. Drill at a VERY LOW RPM and use lotsa cutting fluid or PB Blaster to keep the bit cool and lubricated. That iron pumpkin is some hard stuff.
Lifetime Founding Member
I once had to drill a stuck one out of a 10 bolt Caprice diff. I pulled the axles and carrier, then stuffed the case with rags to contain the shavings. The plug was cast iron and drilled fairly easily. I started in the center of the plug with a small bit and progressively went to larger bits. When most of the plug was gone it weakened enough I was able to turn it with a chisel and hammer and get it out without harming the threads in the diff case.
1 - 9 of 9 Posts
