1 - 8 of 8 Posts
I just bought a rear diff cover and it didn't come with a gasket. Is it OK to use RTV silicon or do I need to find a gasket for installation?
While I'm here what's the best oil for a stock 12 bolt 331 non-posi rear?
As always, Thanks for any replies!
I've always used a gasket and rtv...any name brand 80-90 wt. grease will work...ex.Pennzoil
Bob West
1972 Malibu 454+.030
350 turbo-3.73's
1.79 60 ft.
12.06 @ 112.89
I always just use RTV and have never had a problem.
Just put a good bead on, let it sit for 5-10 minutes until it gets a skin on it, and then bolt it down snug but not overly tight. Then a day later tighten it down properly and fill with oil.
Chris Dagenais
'71 Malibu with a home built 454! [email protected]
For everything you do, this burnout's for you.
CDE Power!
I hate RTV, I normally use a gasket and permatex #2..glue the gasket to the housing, but not the cover to the gasket. That way the cover can be easily removed if needed without wasting the gasket.
Dave
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
72 chevelle
55/57/61 chevies
TC member #493
Never forget Earnhardt!
I'm with Rapid Robert, rtv and gasket, why take chances.
My70ChevelleSS
Craig Sanden
"Together we stand, devided we fall"
cm70
I just had a gear change done a few weeks ago and the mechanic that set it up used a gasket. If you do a search on biggearhead I think you will find that not many know more than he does about rear ends. ( the type in cars anyway)
I would go with what he says. Don't mean to make his head swell up but he was a wealth of information and very helpful with me.
Last time/first time I had the cover off mine, I installed it with gasket and permatex #2. It don't leak, but I'm sure there will be some scraping to do to clean up the surfaces when it comes off again in future. If I was doing it now I'd use permatex on the cover with a gasket and a thin continuous bead of RTV on the housing and install it not too tight and tighten the rest of the way after the RTV cures.
My $0.02
1 - 8 of 8 Posts
