1 - 8 of 8 Posts
Can someone run this new combo thru a desk top dyno for me thank you. Carb 950 hp Intake super victor heads dart 227 flow sheet reads In. .200 145.5 cfm .300 202.5 cfm .400 250.7 cfm .500 285 cfm .600 300.4 cfm .650 301.7 cfm .700 301.7 cfm Ex. .200 102.7 cfm .300 159 cfm .400 202.2 cfm .500 218.8 cfm .600 227 cfm .650 229 cfm .700 229.6 cfm Cam specs soild roller Dur @ .050 In 270 Ex 280 Lift In .688 Ex .672 lobe sep 110 valve lash In .020 Ex .022 Valve timing In 29 btdc 61 abdc Ex 74 bbdc 26 atdc Motor has 11.5 to 1 comp with dish pistons 6 in Rods 4.155 bore and 4.0 stroke Need more input let me know.
Spartan, why is your result so much different than mine?
EDIT: testing things..
I swapped headers with mufflers to open headers and it went to 609HP @ 6500 and 538TQ @ 5000
Then I changed the carb flow rating from 3.0 to 1.5 and got 640hp @ 6500 and 555TQ at 5500
Thanks a yes it will take the RPM used a callies crank with lunati billet I beam rods and wiseco pistons and a LiL M block I will be putting a 275 shot of nitrous on it also and maby trying a 1050 dominator carb Thanks for the help!!:D
1 - 8 of 8 Posts
