1 - 2 of 2 Posts
I installed line outputs on my stock Delco AM/FM stereo Radio in my 71 El Camino, but I am concerned about leaving the amplifier output unloaded (10 ohms). I believe the output transistors may fry without the 10 ohm load. What should I use ? I have already put 12 watt/10 ohm non inductor wirewound resistors across the outputs but they get very hot. My line level outputs do work. Any ideas ?
Is your volume control set to min? Resistors shouldn't get hot with volume control all the way down.
1 - 2 of 2 Posts
