Is it a MUST to degree a cam?? I know guys that just install them dot to dot and thats it. What do you guys think?? Thanks.
IMO Yes!!!!!!!!!!!!!
I have installed many Crane Cams with timing sets when Crane made the gears but used German chains,,, They were ALWAYS on the money
I still had one when we did the Camaro's 400 small block, cam ground with 3° od advance, which put the ICL @ 102°, exactly where I wanted it, so I put it dot to dot and degree the cam, the ICL came in dead on at 102°
Now I have seen the same accurate ground cams with the same timing sets check good on GM cranks but not aftermarket cranks
Some cam cores are off now days on the key location and if they grind to make the key location correct, they grind through the heat treat, so the cam will be off when you degree it. I have seen this 1 given cam core 8° off, swapped in a core of my preference and it was dead on the money
Your really "rolling the dice" and hoping for a home run if you line them up dot to dot
I have seen many engines not perform until the cam was degree'd to find it was 4°+ off which caused lack of low end, have seen them too far advanced causing lack of top end power
Wish you the best if you choose not to but you can buy degree wheel kits cheap, I would suggest using the largest degree wheel you can afford
The Erson Pro Degree wheel is VERY NICE but this is not fit for one time a year use, This thing is durable for people who degree a bunch
