A couple bits of advice-
1. Figure out how to drop & support your steering column ahead of time. Don't bother trying to get the dash out with out dropping it first. It won't work.
2. Pull the drivers seat or the bench seat.
After you've got the new pad on & you are trying to put the main dash back, laying on your back under the dash trying to reconnect all those dumb dashboard lights sucks really bad if you havn't removed the seat.
3. If you are going to do dash work- do it all while the dash is apart. As you will find out, reconnecting all the guage lights is a pain in the A-double-S. If you ever plan to recondition your main dash face/guage cluster, do it now while its all out of the car.
4. Be careful with the guage cluster ground!
That little bugger cost me two days of headaces! There is a ground wire running from the back of the guage cluster housing to the wiring harness. If you don't have a good ground everything will go haywire (oh I could tell you about my nightmare!) So CLEAN THE CONNECTION POINT!!!!
Yuk Dashboard Work
Ben Rambow
My '69 El Camino
The El Camino Classics Club
