just removed mine last night, I will go count the screws and bolts, hang tight I'll be right back.
o.k.,im back, to remove my dash pad, I had to drop the steering column. 2 5/8 nuts and a 5/16 to loosen the gear indicator on the column. then take the screws out of the gauge panel and pull out enough to get a SHORT phillips screwdriver into the opening and remove the (5) screws that point up.
you have (7) 3/8 barrel nuts that also have to be removed. 2 of these are pointing down toward the floor in the opening where the gauge panel is. you cant see them you will have to feel for them. 3 are pointing down in the opening where the glove box opening is, again you cant see them, feel for them. the final 2 point toward the front of the car in the glove box opening. yea real easy
its not as bad as it seems just take your time. hope this helps
Michael
T.C. member # 758
ACES member # 4292
69 malibu convertible
69 malibu h/t 307/pg
<<this space reserved for 66/67 chevelle BB/4spd>>
01 gmc sierra
[This message has been edited by 69ragtop (edited 12-14-2002).]
