That and removing dash pad will do the trick
OOOPPS sorry just noticed its a malibu. 2 blank slots on the warning light row pop out and then the whole cluster can be removed
Philip Mullaly
72 TPI El Camino
You can never fix a Ford,You can only work on them alot.
70 442
The Z-meano
Cowl induction injection
[This message has been edited by pmullaly (edited 06-28-2002).]
Thanks guys,got the dash lights replaced,the turn signal lights were working already,but I still cannot get to the seatbelt light.Do I have to remove the front of the dash face or can I go through the bottom of the dash by removing the a/c duct work?Thanks again Manuel
Go through the top by removing the dash pad. Should be able to get behind the cluster. The dash cluster won't come out unless you remove the entire dash. I disconnected my seat belt warning system 31 years ago. Dumb thing kept going off.
