Last night I was driving my 66 sbc to the gas station and I noticed the dash lights were more dim than normal..when I touched the brakes, the dash lights went out. Let off the brakes and they came back. The headlights stayed the same and did not flicker at all. High rpm's didn't change it either. After I got gas, the battery was pretty much dead and I had to get a jump. Same thing happened on the way home and when I got home, the battery was dead. The generator light was not on and I haven't had any problems with it. About a month ago I installed an internally regulated alternator and the wire kit from AAW. I also put in an aluminum radiator and attatched the ground straps (previous owner had no grounds attatched).
Anybody want to take a stab at this before I start going through it? I suppose I should have the battery tested first.
