when my car is running at nite the dash lights flutter.they keep on dimming low then high.it is a steady blink like. they do not completely go out but dim low than high.
The car with the flutter is a 69 Chevelle SS.The whole light system will do it.You get out and look at the marker lights or tail lights, and they are doing it.Thanks
Bad regulalator! Do yourself a favor and install an internally regulated Delco, then you can eliminate the regulator and all of that wiring. 2 wires (1 from battery, second one is 12 volts from ignition source) and your set to go.
