I'm removing a sweep dash preping for a gauge dash. How do I remove the light switch from the assembly (I am trying to keep everything in tact)
I just removed my sweep dash, and I didn't see how it came out either. But, you have to use a different light switch on the gauge dash, so I just left mine in.
to remove the knob you need to pull the stem all the way out then on the side of the switch there is a little steel button with a spring under the head of it
press that little button and the stem will come out then just unscrew the mounting bolt that the stem goes through and the switch will come out
