Dash interchange
790 2
Will the dash out of a 1967 chevelle fit into a 1966 chevelle. I had assumed that it would, but I recently heard that the strip in the top of the 1967 dash will not work with the 1966 dash. Anyone shed some light on this and I would be greatly appreciative.
There are a couple of differences between 66/////67 dashes none of which make the swap impossible. You can either use a 67 dash strip on your 67 dash or you can move the wiper switch hole t o the left to line up with the 66 dash strip.You will also need to drill holes for the glovebox bezel.If I have forgotten anything someone will point it out
I have a 66' dash in my 67'..............
Shannon
