1 - 1 of 1 Posts
Just finished installing a VHX dash in my 67 Chevelle and will be going through the settings this weekend and was curious what people are running. Some are pretty standard / default stuff like fuel sender and such. But was curious what warning settings, for example, people are using for water temp, oil PSI, Voltage etc... and the dimming options for day and night settings.
I figure a lot of it is a personal preference with regards to dimming (I'm running the red dash) but if people have already tweaked a good non-glare setup would be a good starting point. And for the temp settings, I have the switch in the filler neck on a 327ci motor, the oil temp at the back of the block by the distributor.
Anyway thanks for your time.
1 - 1 of 1 Posts
