I have a 1998 crate 5.7 vortec laying around. Its the version with 4 bolt mains and hardened exhaust seats. It has 25,000 miles on it when I pulled it and was thinking about putting it in my moms 1980 vette ( 4 speed car) after a rebuild. I bought the engine new for my truck but it was totaled so I pulled the motor back out
It was going to be stock except for headers an edelbock dual plane, 600 cfm carb. and the gm hot cam ( listed below)
it was factory rated at 255 /330 hp/ torgue. Do you think it wil hit 300 HP?
Intake Duration at 050 inch Lift:
196
Exhaust Duration at 050 inch Lift:
206
196 int./206 exh.
Advertised Intake Duration:
288
Advertised Exhaust Duration:
308
Advertised Duration:
288 int./308 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.431 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.451 in.
